box design needed
more info is needed. what freq do you want your boxed tuned to. how many cubes per speakers do you need.. what are you size limitations. do you want port forward speaker facing up, port back speaker forward etc....
-=Jason=-
:)Loudest Design Possible....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
speakers up, back, forward
port up, back, forward
its a midsize suv
size limitations are 42''W 30''D ??''H
subs are kicker l5 12 squares dual 2ohm
Resonance Frequency [fs], Hz 32.2
Effective Piston Area [sd], in2 (m2) 99.98 (.0645)
Effective Excursion [EXmax™], in (mm) .51 (12.9)
Mechanical Q-Factor [Qms] 11.884
Electrical Q-Factor [Qes] .594
Total Q-Factor [Qts] .566
3.25 ft3 + port displacement per sub
(3” x 13.25” port, 14.5” long)
sub displacement is 131.1''
im kinda looking for a 2d drawing of what it needs to look like. i was hoping for a build log that someone else had done similar.
so when i get started on this guess i will be making a build log.
you could get a box design from the free box plans sticky. there should be a 7 cube desgn in there somewhere. not sure if you've heard these subs before, but you're on the right track. they get pretty loud in 3.5 cubes.
d-REW
tuTWENTY
d-REW
denver COLORADO
d-REW
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
