box design help
Yea, do that...but with a bit more...try this..
-Get some 1.25" long drywall screws (coarse thread)
-With the sheet that the sub will be resting/mounted on facing up...predrill holes (not all the way through the second sheet...just enough through so the screw has something to be guided into) once you have the two sheets lined up square to each other (one ontop of the other)
-Then cover the sheet with the larger cutout with glue and then screw the two sheets together using the holes and screws mentioned before...theyll be held together and with no screws visible //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
littledude
littledude
MI
Pioneer~Saturn
