box design help
jr15
Free-Air Resonance: fs 27 Hz
Total Q: Qts 0.362
Mechanical Q: Qms 3.89
Electrical Q: Qes 0.399
Compliance Volume: Vas 3.08 ft3
Maximum Excursion: Xmax 0.750” (+1.500”)
(peak to peak) 19.00 mm (+38.00 mm)
Voice Coil DC Resistance: Revc 6.4 W
Effective Cone Area: Sd 83.48 in2
Driver Displacement: .18 ft3
can anyone here help me design a ported box for my vega128???? those are all the specs..let me know if anyone can help....it will be going in the back of a 95 blazer...thanks for any help guys...
30" X 15" X 14"- 2.783 ft^3 internal after wood displacement.
Tuned to 35 Hz
Vent(slot)- 13.5" high, 2" wide and 16.96" deep
estimated peak- 41.92 Hz
Tuned to 33 Hz
Vent(slot)- 13.5" high, 2" wide and 19.62" deep
estimated peak- 41.06 Hz
Let me know if you want any other volume/tunings....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok thank you...
hey shaun i seen the elemntal designs pic under your name...so i thought i should ask you another question about a different box...im building a sealed enclosure for 2 e10k's tell me if this sounds ok 26"w x 12"h x 9"d...it will be 2 separate chambers so i dont have to worry if one sub blows....thanks for help
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
762
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
565
jr15
jr15
Steelton, PA
jr15
    May 22, 2024
    May 22, 2024
