Hey everyone I'm hoping to get some help designing and tuning a box for 2 18" RE audio SX18's
What I really need is the correct type of port and size and location of it. I'm ok with subs up with port up but also subs up and port forward between the seats.
It will be going into my 2007 dodge ram 1500 quad cab.
Plan on using a single Hifonics BRX 2400.1 @ 1ohm unless I decide on a more powerful woofer and will use 1 for each woofer.
I have made this in sketchup as it will be close to my max size I want to fit in the back of my truck.
Max OD W=60" H=24" D=26-27"
Material Thickness will be dual layer 3/4" so 1.5"
Looking to tune it to 34hz
Will be playing mostly music but want it to be loud and low
Woofer = If you can recommend a better woofer in this price range let me know!
RE Audio SX18D2 (SX18-D2) 18" Dual 2 ohm Car Subwoofer
SX 18" T/S Parameters:
Electrical Q Value (Qes): 0.53
Mechanical Q Value (Qms): 6.1
Total Speaker Q Value (Qts): 0.48
Free Air Resonance (Fs): 33.2 Hz
Equivalent Compliance (Vas): 159 liters
One-Way, Linear Excursion (Xmax): 22 mm
Efficiency (SPL 1W/1m): 92.7 dB SPL
Effective Piston Area (Sd): 1210 cm2
DC Resistance (Re): 1.9 ohm
Nominal Impedance (Znom): Dual 2 ohm
Thermal Power Handling (Pe): 1000 W
Force Factor (Bl): 21
This box will have a 3" baffle to get my 24" height but could change it to 1.5" if it improves performance with more volume by increasing Height.
ID H=19.5"-21"(21" if 1.5" baffle) W=57" D=23"-24" (24" makes me scoot my seat up an inch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)
And thanks in advance for anyone bored enough to help me design my port for this box!
