Xprime4
****in' canadian
after losing some hair, some patience, few hours and some sleep, i finally think I (with the help of few) think i've got something ok. I ain't good with design software so there won't be any pics before the build start but i just need a confirmation on what i'm doing //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Box will be 37,25 width x 21 height x 22 deep = 8.261 ft/cu before all displacement
Sub = fi Q 18 (27mm xmax) and .24 ft/cu displacement
Tuning expected = 30-32hz no more/ no less
Power will be around (+/-) 1500 watt rms from bxi1606d @ 1ohm. I may set it around 1400 for safety purpose.
Aeros port will be pvc tube from home depot of 4 inch. (i think it's internal)
I've used carstereo calculator but still... they told me i need at least 12.99 inch of minimum diameter (i'm at 16) and minimum 132.53 inch of port (i'm at 754.93???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif).
Calcul: P x 2square x 13.01 x 4 aeros = 755inch/cu.
The 13.01 comes from carstereo calculator for 32hz in 8.3 but i'm not sure i need to input the net volume (after sub/port displacement) or the total internal volume before all displacement //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
The aeroports will be on the left and right side of the box 2 per sides. Sub facing the roof of the accent 99 hatchback.
There is no other way of doing it coz of aeros cleareance issu.
I know i need some kind of bracing to help the aeros straight, what could i use? I only got acces to a local home depot //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
How will the bracing displacement affect the tuning freq? should i make the port longer/shorter and am i doing something wrong? If i get the start signal i may start the box building this afternoon....
Please help a poor guy with no selfesteem when it come to tuning calculs.
