Box design for Fi BTL
go with Fi's high recommendations 5 cu/ft @ ~33Hz.. you will be happy and yes bracing always helps if you have the space.
Ok, i'll do double baffle and brace it. Yeah I was planing on doing a sloted port. Whats threaded rod? Is it just a dowl rod? What kind of wood is best and what thickness?
Threaded rod is stainless steel rod with threads along the entire length, like a long screw. Wooden dowels would work fine though, if used properly.
MDF is the wood you will want, and 3/4" will be great. If you want to go the extra mile, Birch is much lighter and stronger than MDF but will cost a pretty penny...
Search and read the stickies in this section, it will help a lot when getting started.
Good luck.
Good luck.
This will be my first system. I hate doing things Half A$$ed so I want to go all out, I might get the birch. I dont have enough room for the 18'' /cry. Well thank you I think thats all the questions for now.
Good luck.
Negative.
It's like $10 more for a sheet.
I will never use MDF again after using Birch.
Wragold
Wragold
Charlotte, NC
kicker06
