Box design conflict
SoundWave.Co
:confused:I have a new woofer I want to experiment with, before I build more vehicles with it, but I now have 2 different designs for it. 1st one I got was from PWK, and it's internal volume is 5.37ft, and the design I got from the manufacturer is 9.6ft. I am looking to make this woofer as loud as possible, with out sacrificing it's music capabilities. It is going into the back of a 2 door Yukon/full size blazer. I really like the low bass since I have an epicenter, but would like it to sound good on most music also. Can anyone halp me out with a design or input, Thanks.
T/S:
Fs----------31.467 Hz
Qms--------3.162
Vas---------61.844L
Cms--------0.643mm/N
Mms--------343.62g
Rms--------1.691kg/s
Xmax-------21.0 mm
P-dia-------322mm
Sd---------0.081sq. M
P-Vd-------1.709L
Qes--------0.529
Re---------0.8ohm
Le---------1.548mH
Z----------1.0ohms
Bl----------11.538 Tm
Qts---------0.479
No----------0.503%
1-w SPL----89.1 dB
2.83-V SPL--99.22 dB
(EBP)-------59.93
Well, first off...you should question Pete's design. If those are true parameters, then his design will work great. However, if the parameters are incorrect or are of brand new un-broken in drivers...then you might have a problem.
The parameters are for a 15" subwoofer. Typical compliance of a 15" subwoofer is between 3.5-6.0cf ported. 9.6 cf is kind of off the charts...unless you want a huge gain around tuning. Also, without knowing anything else about what you're looking for or tuning, there's not much we can help you with.
tuan
tuan
tuan knows his stuff so does pwk. and i agree 9.6 for a single 15 is //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif unless its for home theatre..
Thats what I thought, the only reason I have looked at PWKs twice, is because originally, the design was for 2 woofers. Since then, I decided to use just one woofer, essentially using half the box. When I asked Pete about it, he said it may not work.
tuan
I want to achieve maximum spl and loudness, and still be able to play music, maybe up to 50Hz. But I am more into the lows myself, but this is somewhat a demo vehicle too, so I need to be able to do more than burp and it is a daily driver too, so I will be listening to music on it.
The reason why half of it may not work is because the transfer function of the design is different. When you cut the box in half the design changes entirely. The so called "space" that your enclosure takes up is now opened up. The vehicle environment has changed hence the design may need to be different.
Tuan
Tuan
hmmmmm:rolleyes:
Tuan
hmmmmm:rolleyes:
Tuan
hmmmmm:rolleyes:
SoundWave.Co
SoundWave.Co
Spokane, WA
SoundWave.Co
