box builders, can someone please help me asap
t-money
my friend built a box for my 15 mag but i want to make sure its built properly. The box is 3.7cf tuned to 27hz. When i confirmed with my friend that the box is tuned to 27hz he told me the the box has 25sq inches of port. I know theres more to determine tuning like the length of the port. So my question is how long would the port need to be so my box is tuned to 27hz. Any and all help is appreciated.
you serious? that could **** cause thats the formula i used to get my box to 28hz so mine might be way off
EDIT: I used another calculator and got the same number again *SHRUGS*
so does around 26 inches sound about correct for my box to be tuned to 27hz, or should it be smaller? What is the formula i would use to find out exactly. thanks for all the help so far guys
this isnt complicated...
::eek:pens WinISD::
::picks random speaker::
::enters 3.7cf @ 27Hz::
::puts a 5x5 slot port::
::Gets 21.41::
that is without end corrections (if its flared or if it has a wall close to it it doesnt have to be as long)
FYI 25sqin is NOT enough for that enclosure with that driver.
::eek:pens WinISD::
::Gets 21.41::
well i've been told atleast 25sq inches of port , how much port should i use?
t-money
t-money
Toronto,Ont
t-money
michigan born
    May 14, 2026
michigan born
    May 14, 2026
