Lemme check some rates....sounds good. I am just REALLY eager to get this going. What if I gave you $60 to speed up the shipping? Would that help some? I know air is more expensive then ground, but will $60 more be enough? I just really want to get these babies hooked up.
Here is what DHL says, personally, its not worth it.sounds good. I am just REALLY eager to get this going. What if I gave you $60 to speed up the shipping? Would that help some? I know air is more expensive then ground, but will $60 more be enough? I just really want to get these babies hooked up.
A top mount, you just actually mount the amp onto the pedestal, its for glass boxes. A flush mount it will sit down into the box, making the top of the amp flush with the top of the box. It will take some extra time, and were kind of limited on what size amps we can put in there and not get in the way of the port, plus it will slightly change the tuning with the loss of airspace inside the box.yeah, those seem too high......nevermind then. I need something to waste my 62 bucks on because paypal wont let me withdraw and put in my bank until another week or so because ive went over my limit
what would a top mount amp rack look like? and will that take a while to put in?
Thanks man //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifBj = great carpenter.
I will do some checking into the birch. I dont think it will be much lighter than the trupan, but im not for sure. Ill compare the 1/2" birch we stock to the 5/8" trupan we also stock, and compare weights with that.Another good lookin start. BJ, I might be hitting you up next week for another build, I'm picking up some DD 3510's so as soon as I figure out what I'm gonna do I'll give you a hollar.
I'd be interested if that 13 ply birch would be any lighter than the trupan you normally use. That last box I got from you was pretty light compared to what I'm used to.
Right on, I'm guessing it might be hard to justify the cost to weight savings, but its always worth a check.I will do some checking into the birch. I dont think it will be much lighter than the trupan, but im not for sure. Ill compare the 1/2" birch we stock to the 5/8" trupan we also stock, and compare weights with that.
