Box Build for Toyota Tundra - Two RF Power HX2's
I agree. Subs>friends comfort.
Edit~I missed the part about you getting the new wheels.
Your build looks very nice though, that HU is beautiful. I agree that you should get rid of the rear seat bottom and replace it with the box. Would be a lot of work, but I don't think it's impossible.
Great work!
Man I have your trucks little brother. White tacoma access cab tinted. Does that have the 4.7 in it or the 4.0 V6. I didn't see any fender badges so im gonna assume the V6. I almost wanna get another 12" in a ported box and run dual ported 12" in the back of my taco. Only problem is I only got a 500w mono amp and a dual one woofer.
Build looks nice man. I like the truck. Should look nice with the lift and rockstars.
Nice build man. I need my seats every once in a while too, so my box sits on the seat like yours. I really can't think of a good way to keep it from moving and not looking horrible. I was thinking about running some spare 4ga around it and bolting it back to the wall.
I took off the fender badge 'cause I found it clunky. It has the 5.7L V8. Thanks.
I ended up using some adjustable strapping similar to seatbelt strapping, but only 2" wide, with eyelets in both ends. I drilled two holes in the box, 20" apart from one another, and bolted the two straps to the box. On the inside, instead of using washers, I used a 3/16", 2" wide plate that I drilled two holes in, and used that plate as the washers to give it more strength in case I were in an accident, i was worried that using seperate washers would just pull right through the box. The straps are bolted to the seat mounting bolts. The box does not move.
valin
The King of the North
valin
Sudbury, Ontario
Ben Scroggin
