box build for stang_01
kentb
box build for stang_01(SMD.COM)
for 2 15" Fi BTL's
tuned at 35hz
6.5 cubes net after displacement
box will have 45's, glassed corners.
port will be painted black, wrapped in black carpet
dust FTL
glassed corners
braced and glassed
double baffle
well can i throw some advice at you
if your doing the fiberglass corners an this box is for spl i would really consider sanding that stuff smooth an we are talking smooth as possiable, you would be amazed at how much or how many db's you gain doing so. if not then don't worry about what i said nice box. should be pretty nice when done.
box is done, turn out good, rock solid! i added more 45's and some resin 45's on areas to make it stronger.
just need to clean the dust on the carpet.
kentb
kentb
Las Vegas
kentb
    Jun 20, 2026
    Jun 20, 2026
