Pitchblack98
Read all of this before you reply please... Don't just skim thru it. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I'm designing a box for (2) 12" Alpine Type Rs that will run off of (2) M1005 (One per sub). I have everything figured out for the most part. I was planning on a ported box, but I don't think I have enough room. My plans were calling for a 4 cu.ft. box with 30 sq.in. of port area per sub, 60 total. My port length needs to be 29 inches to tune it at 32 hz. I have about 5.5cu.ft to work with according to the dimensions of the extended cab of my truck and I may pic up another cube give or take because my amp rack will be raised...
The face and top of my box is going to be fiberglass. I may make the bottom fiberglass also. The rest of it will be MDF. I'm still working out the construction process of my box.
Now my questions...
1. I'm looking for a good sounding bass. Not too boomy. I'm looking for SQ or SQL, I'm not too conerned with SPL. I listen to a lot of hard rock for the most part and the occasional hip hop. Do the Type Rs really not sound that great in a sealed box? I may not have a choice between a sealed or ported box. I think my ports are going to take up a lot of my box and I will be under 4 cu.ft. when its done. Possibly not thought.
2. I plan on building tray/boxes for each individual amp. I have (2)M1005 and a F345. They are going to be fiberglassed into the top of my box rotated and at a slight angle. Basically all my wires will have to run thru the internal area of my box. Is there a better way to go about this to keep to wires out of my box? I thought about using some 2" PVC pipe and running it from the bottom of my amp trays to out the back of my box. There would be a single pipe for each amp. That would keep my wires out of the box. Granted they will still be going thru the box, but they will be in a PVC pipe. Does that make sense what Im thinking about doing there? Let me know if there is an easier way to do this that I may be over looking...
3. If I do decide to try and make a ported box work does it have to be a single port or could I do 2 ports. I'd like to do 1 port on the top of the back centered in the rear and have it raised out of the top of the box to so it would match the raised area of the amps. If I did it this way I could get about 4" of length that would stick out of the top of the box. That would help with the port length and keep my port from taking soo much area out of my box.
I've built many sealed boxes over the years and I've only done one ported box a few years ago. I just bought a new truck and I'm going to have it for a while so I want the stereo to look nice and sound good. Any help is appreciated! //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
Now my questions...
