if the cap is limiting power, you can test with volt meter to see voltage at amp while playing the subs at a medium to loud level. check voltage with car on volume on radio all the way down, then turn up to your listening volume. look to see how low the voltage drops. it shouldnt really even drop below 12.5v in yer particular setup.
** sorry for the long post **
watching the capacitor read-out before, it used to go down as far as 11 sometimes 10v at high volume, witch is where the exessive thermal heat is being caused, i can cruise around all day with them at medium volume and listen to them perfectly clear they sound great and all with no over-heating issues.
As soon as it gets loud, the volume goes up then the capacitor starts to drop voltage pretty bad and i think this is when the subwoofers start to over-heat.
What i mean though, is that because the capacitor is directly hooked up to the amplifier instead of my battery, could this be not enough power to make the amplifier turn out all of its RMS that it is supose to at 1ohm ?
then i have to go ahead and crank up the gain-settings to compensate ? i have always thought this because the middle of the amplifier neons never are fully lit, and the amp has always had to have the gain cranked to be loud. I have read in other forums that your amplifier will only turn out as much RMS as your electrical system will allow, maybe that is true with this case and in-turn causing me to over-compensate with the gain setting.
Hopefully spending the 120 $ to get the battery installed will be worth it, and clear up the issues. I have been wondering ever since i got the amplifier why it has been so quiet unless the gain is cranked up all the way. I also have to agree with the poster who said there must be somthing else going on more critical than the box. Sure it may not be exactly to spec, but its still good enough so that they should not be over-heating this bad.
4 FI btl's in a SUV that has to be what, 5.5 cubic feet per sub? ive seen vids of the vehicle and the thing still has its back seats, so its not like that wall of SX's in the picture above, so oviously you dont need to have that gigantic of a box just for 2 18''s. I am positive that there is somthing else going on here, eletrical related causing the amplifier to not turn out its true power, and thus causing me to turn the gain up to much and clip the subwoofers and cause the over-heating.
It is a re-assuring feeling to know that i can drive around and listen to them now on moderate volume without any over-heating issues, but i still want to be able to let thease things bang.
The amplifier issue has been a problem from the very start since i got the amp installed. I just never thought anything of it because my MA audio's held up against the abuse then gave way, then when i dropped thease subwoofers in i never thought anything of it until now, and now i am positive or atleast more than i was before as to what was causing the problem that it is likely a lack of propper power for the amplifier.
But yeah, i remember reading articles stating that your amplifier can only put out as much RMS as your electrical system will allow, so that right there if true could be the key factor in why my **** amp sounds so quiet unless gain is cranked.
With a kinetik hc 1800 upfront linked with the HC2000 i am going to put in the back, that is more than enough battery power and i have a 140 amp alternator
( saw the poster who forgot what size i had )
If this doesnt resolve it, then i supose it is the box its self, but i highly doubt that as i have said i can run them with the gain turned down to 12'oclock for along time with no over-heating issues, they just sound alot quieter then they should and they hardly move you can tell the amplifier isnt putting out much power, Until the gain is turned all the way on.
I am sure this is the problem, and when it is taken care of i HOPE to god thease things function propperly. If they do i will probably move onto FI BTL's anyways as those things kick total *** and we just got a nice *** tax return !
So i will use thease to trouble-shoot the issues, and hopefully resolve them and use them as a in-between woofer until i get my BTL's, Witch are alot more durable, handle more RMS, have cooling options, and overall are an upgrade in subwoofer witch would help alot in my situation, also they require .5cubic feet less space than the SX's per sub witch is nice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-andrew
