Boston Acoustic Z6
mkell
I am looking into getting the Boston Acoustic Z6's for my front doors. Since these are 3ohm speakers, what ohm rating do I need to run from an amp? I am trying to figure out what amps I need to look at b/c I have no idea what goes with 3ohms. Thanks!
-Matt
Everything goes with 3ohm....you'll be fine with anything. I had Boston Pro's (also 3ohm), and ran them for over a year on an amp that WAS NOT stable below 4ohm/channel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Never had a single problem......
Thanks. Should I run them at 400w (which is supposed to be the max for the Z6) ir should I back it down a little?
BA's do love power //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif I had a 400w x 2 @ 4ohm amp strapped to my BA Pro's, and they loved it. I would go with the 400w, and then just back it off a little if you need.
I had Boston Pro's (also 3ohm), and ran them for over a year. .. Never had a single problem..
Squeak, after reading a bunch of your posts, you keep mentioning those BA Pro's in the past tense. Why aren't you still running them? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
LOL....No reason other than I like trying out new stuff //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally sold them to go active DIY, but then I bought a house and a bunch of other things happened. So, about a year and a half after I sold them (ran stockers that entire time //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif ), I decided I wanted to try out horns instead of going DIY with "standard" drivers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for all your input! Do you guys have any recomendations for amps that can do 400w? Also, 2ohm or 4ohm?
I ran an Eclipse 34230 to my Pro's. Not in production anymore, but you can pick them up on egay for pretty decent prices. 400w x 2 @ 4ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Excellent, excellent amps. Just be aware that they are not very flexible....they ARE NOT stable below 4ohm per channel and ARE NOT bridgeable. But, like I said...ran my "3ohm" Pro's just fine.
mkell
mkell
STL
stangme01
