csu87
found another cheap amp on cl. its a boss pd4000 let me know if you have any experience with these.
SPECS
RMS Watts/CH at 4 Ohms 500W X 2
RMS Watts/CH at 2 Ohms 900W X 2
RMS Watts/CH at 1 Ohm 1500W X 2
MAX Watts/CH at 0.5 Ohm 4000W X 1
S/N Ratio 105 db
Input Sensitivity Push: 100mV -2V
Pull: 2V - 8V
Low Pass Crossover : 50Hz - 120 Hz
High Pass Crossover: 120 Hz - 720 Hz
Low Boost 0 - + 18 db
Bass Frequency : 40Hz - 100 Hz
Frequency Response : 9Hz - 50 Khz ( +/- 3 db)
THD @ RMS Watts 0.01%
Channel seperation : 90db
SPECS
S/N Ratio 105 db
Pull: 2V - 8V
