Crownvicon28s 10+ year member God 1st 1,638 4 Spartanburg, SC Jan 21, 2009 #1 Can someone give directions and post pics on how to use bolts as my terminals on my sub box? Click to read more...
jco1385 5,000+ posts expert jcologist 19,957 84 Mobile, AL Jan 21, 2009 #2 drill a hole as big as the shank of the bolt. wire from the sub to the bolt. then from the outside of the box bolt to amp. use ring terminals on both sides, washer and nut on outside
OP Crownvicon28s 10+ year member God 1st 1,638 4 Spartanburg, SC Jan 21, 2009 Thread Starter #3 Ok thanks.
jco1385 5,000+ posts expert jcologist 19,957 84 Mobile, AL Jan 21, 2009 #4 make sure you use 2 bolts** one positive/one negative. or you could do one for each pole (if it's a dvc) and jump it outside the box.
OP Crownvicon28s 10+ year member God 1st 1,638 4 Spartanburg, SC Jan 21, 2009 Thread Starter #5 Ok gotcha
