bmw install
Had a 01 325ci.
I know you remove that trim panel that goes from left to right and around the HU. Never did it myself, but there is a place that sells a LCD Trim panel, and he has a write up of the install. Check e46fanatics (4got the name of the forum).
first you have to remove the trim, i had a 3 series, if you have alluminum trim you haeve to remove these they will show you screws you have to remove those screws and your stereo will come out, i installed my AVIC n2 a while back, if you show pics i can help you.
rj
Here's what i came up with for ya im not sure which you needed so i posted both:).
All:
Remove trim for center console.
Remove insert in function carrier.
In version with on-board monitor, remove heater controls.
87203990
Loosen screws (1).
87203991
Loosen screws (1).
Pull out function carrier for switch center (2) in direction of arrow
http://library.alldatapro.com/alldata/LIB~C35391~R0~OB0~P3R0H~N/0/73323165/88140390/88140443/88140446/34853741/34866522/56287413/56287631/55046354/78443400/87203989/87203992
Disconnect plug connections (1) and (2) and remove function carrier for switch center (3).
That is for the center console
Ok so I finally got to see the BMW that i'm installing in...it's hella nice...not something that I would want to own myself, but hella nice...so anyway needless to say I want this install to go flawlessly...I was psyched to find out that the battery is in the trunk which is for obvious reasons, really sweet...here's what's going in:
Avic-N2
JL 1000/1
2 JL subs(they are 12's not sure what series...I will find out tonight)
So I guess I am just looking for general advice from anyone who has installed in a 2001 bmw 330ci coupe or has installed an avic-N2...
goodstuff
LOL
goodstuff
Northeast
AVSTANG02
