Blowthrough through back glass of truck
  • 4
daltone34
US
So. I just got a camper shell and plan on doing 6 12s in a blowthrough through the back glass of my truck and I have a question. If I were to build the box like the picture on this post, would it be considered a sixth order or would it be fine to build it To the specs of a ported box?
Sent from my SM-N920V using Tapatalk
have to get @Jeffdachef on this one.. we had a guy at shop i worked at many years ago had 6 12's ported through rubber boot on back window with camper shell, soundstream amps/subs, it was loud a/f is all i know about we didn't do that just his hu and eq.. was a guy here did 8 planet audio 12's in truck bed box only 1500rms hit like 150db ported through hole in back wall no camper shell.. i'll see if i can find it
That would be an unloaded 6th order
Seal up the rear and make the front a port for a 4th order
Also you should be able to fit 12 12's no problem with a design like that
Or you could do flat sealed wall with the 6 and port through the window
That would be an unloaded 6th orderSeal up the rear and make the front a port for a 4th order
See I tried a 4th order with an 8 just to test the sound and all and I didn't really like it.. they're just too complicated and unless you meter it while you tune and build and such then you'll never get the sound and pressure you want.. and I've never really liked a sealed box but it just depends on how much air I could be pushing if I did do a flatwall sealed.. would I just do a regular sealed wall to specs and leave the window alone? Wouldn't it act kind of like if you had a c pillar wall with seats (the back wall) in the way?
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
daltone34
daltone34
US
daltone34
    May 12, 2024
Brendon Jenness
    May 11, 2024
