Blaupunkt 10s SPL testing
  • 6
Id like to see what they would do in a 4th order
who is this man!?! we must find him/her
Green line is the 10s, orange line is the 8s. 44hz is the magic note, you will notice they are close, less than 1 db close. This will be a slow side experiment but I will happily share the results when I measure them. The goal is to do at least 141 with 2 8s clamping under 900w.
thnaks again I could not find this product in europe so I will go with this one ...
10
Lookslike the amplifiers recommended should work just fine with Either Chs 1&2 or 3&4 bridged/mono mode/LPF should work just fine as well as using...
16
4K
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
THATpurpleKUSH
Fuckyou
THATpurpleKUSH
Slums of the Shaolin
THATpurpleKUSH
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
