Bit of help would be lovely
kodaz
Hey boys
listen I have a question regarding AUX input on heads. I have a pioneer 8200R (the dolphin one) and I'm thinking about the best way to hook up my new in dash tv so that i can play the audio through my head. I There seems to be at least 3 sets of rca outs on the back. One is non-fading sub, the other two are for the front and rear amp, but I can't see rca in's. It also has an IP-bus which i have no clue as to what it is (maybe the cd-changer control). Anyway was wondering if anyone has this unit and if its possible to hook the audio through it.. It was a high end unit bout 2 years ago I think.
If not, I also have a Tv tuner coming with the lcd which has rca in's and outs... only problem is my head unit it hooked up to all the speakers individually and the rear amp is only powering the sub. So if I plugged the rca out from the head into the tuner and used the tuner to connect to the amp.. i would only get base. This prolly makes no sense.
Hope someone can help me
You can't hook the TV to any of the Pre-Outs on your HU, that wouldn't work at all. If you don't have an AUX in or set of RCA in's, you'll need to get an FM modulator for your TV so you can hear it through the HU. There really isn't any other way.
Don't be so strict snova... Kodaz is from Austrailia. They're 'different' there...
kodaz
kodaz
Australia
eengrms
