Bigger single aeroport VS smaller dual aeroports?
  • 5
mike12
Im building a new box design for 2 sa12s on 2k currently have 2 4inch aeroports 12inch in lengh. was wondering whats the difference if i ran one 8inch aeroport vs having 2 smaller? might have the port firing the same way as the subs or off to the side still undecided.
Thanks
2 4 inch ports arent the same area as an 8 inch port.. it wont matter if the area is the same. you're asking about different port area though
im just wondering if i ran one single aeroport rather than 2 what the difference would be?
cant you just change the length of the 6 inch?
Yes, you can but as you go bigger in diameter, the length needs to be much larger for the same tuning. Takes up more space in general. I would recommend going with the 6" if space allows you as that'll be more ideal. If not, you might have to stick with dual 4".
I have mused doing that, but I like keeping my jalopies looking OEM. Now if I knew how to fiberglass like NSTALN, I would have done it long ago.
22
Back in the day there was some that went directly into the dash and then came out when powered on. Some of those were bigger then the size you are...
Damn.. thank you man... I wasn't expecting you to do all the work for me but I'll definitely take it lol. Thank you so much and also thank you...
I sincerely appreciate the advice. I've made some changes to the design of my box and it's coming out to +8.99% larger than spec. I'll still be...
mike12
mike12
Elyria Ohio
Jeffdachef
    Jun 15, 2024
    Jun 15, 2024
