bigger box less power!?
chitowns finest
Raw power and ignorince,
hey i have a stroker 15 in a six cube box although the manufactur suggests 3 cube for it. now i only have a kicker 1200.1 on it even though my sub is rated for 2000 watts rms.so i am employing the bigger box lower power rule by making my box twice an big now my sub is smoked. its no big deal cuz a new cone for it is only 40 bucks since they are field replacable. to avoid blowing it up again can some one explain the sience of bigger box less power to me??for those who dont understand this concept it is used in competions to get the same spl from a sub in a bigger box with less power as if it was in a regular box with max power.
i dont like small boxes + cewin vegas specs put the tuning freq at 32 hz what music plays at 32 hz??!! also with the bigger box theory i can get 2000 watts spl from my 1200 watt amp! no good??
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
A larger box will reduce overall SPL.
Hoffman's Iron Law, like Jmac said earlier. Larger boxes are simply more efficient and will send a driver to its mechanical limits sooner.
As said, bigger boxes are more efficient, so it takes less power to reach the mechanical limits of the driver. In this case, the mechanical limits were probably less than 1000wrms.
To be more specific, that's frequency dependant. Yes output will be down across most of the useable range, but output in the lowest octaves will actually increase.
My personal experiences, plus look at the DB numbers section in competition section... Almost 90% of those with high scores have huge boxes for the subs they are using. I personally like to go 1-1.5 cubes more than what the manufacture recommends, im not saying use a 9 cubes for a 10" woofer though;)
chitowns finest
chitowns finest
chicago
audioholic
