Big three on a 96 explorer
Just make a new engine block to chassis if you can't find the old one.
What's wrong with using the original ground on the battery? You're just adding wire to it and sanding down the metal to provide less resistance.
nuttin like straight line 'n it. Thats actually a good idea, grounding to the Alternator mount, JUST MAKE SURE you are able to route the wire away from any extreme heatsources or moving parts of the engine. It is important to upgrade the size of both the positive AND negative leads... Don't cause a bottle neck in your electrical system...read these threads for more info.
Wire size guide: http://www.caraudio.com/forum/showthread.php?t=166038
BigTHREE: http://www.caraudio.com/forum/showthread.php?t=152355
Flow of electricity: http://www.caraudio.com/forum/showthread.php?t=187534
The factory ground is a 4 gauge that chains the frame to the passenger side of the motor, with a smaller body and computer ground. Then there are a bunch of ground straps interconnecting everything.
JBloud47
JBloud47
Louisville, Ky
johnecon2001
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
