geowick07
i am in the process of researching my nex system. i have found that the amp i am getting does not except 1/0 wire. only up to 4 gauge. so, i have gone in the direction of using a distribution block instead. will be using an orion 2400D amp, running to 2 Kicker CVR124's. also, in the future, i will be adding another amp for the component set i am looking at. if i buy this distro block, will it work?
http://knukonceptz.com/productDetail.cfm?prodID=KNF-23
this way, i can run my sub power thru it, which needs 1/0 power wire thru it now, and when i have the other amp, it can also handle the 4 gauge power. Is that right, or am i completely off-base?
thanks in advance for any help with this one!
