Beware AQ HDC3 Issues ??
It is a end user error for throwing 3kw to it when they are only rated for 1kw
I Am not product bashing NOR am i company bashing. Im not trying to put the company down at all.
I am just saying that be careful as to how much power you throw to your sub. i would not suggest doing 3kw daily.
I guess the title should be labeled differently as i now see where it sounds like i am Company/Product bashing
When you said "Beware of what your purchasing" I took that to mean the sub was defective, I clicked on this thread thinking that there was a problem with the sub, that's the feeling the title gave me.
Maybe take out the "beware" and change the title??
I meant beware of what your purchasing because everyone is under the impression that the newer version will take the power if not more than the older version
so HDC3 > HD3 was the impression i was getting but i feel its the other way around
HD3 > HDC3
Did you use an O-scope to check for clipping? The coil can take 3k all day if its the aluminum coil, but to run 3k the box has to be perfect and you cant go below tuning and you gotta make sure you got you SSF set correctly. You blew the sub i bet due to overexcursion due to either playing below tuning or improper SSF settings.
15s..but i highly dout tuning had anything to do with the woofer blowing..
I think it could have played a role in it especially with those kind watts pushing it to over exert (spiders ripping) could be many many reason why the subs did that. I cant judge because he didnt list all the facts of the matter such as how long of a period the music was played, what kind of music, box design.......But I know he pushed them to their limits on PURPOSE, like mentioned before he would of smelled something before the coils went and could of stopped it, BTW alum coils can handle more power than copper. Also could of been from the ripped spider causing the coil to rub or shift. Either way its the end users fault.
Honestly any subwoofer out there could do the same thing with that power daily.
egg
HD3 > HDC3
Fair enough
egg
yes..i totally agree with that..no woofer is going to like 2k+ daily on music for a long period of time..unless it has a 4" Coil..which i wouldnt even get for music needs lol..
my thoughts exactly!! Just way to many factors on the reason why this happend.
egg
Wow man i dont know what to say.. I never had a issue with them at all.... I even threw a strapped pair of SAZ3000D's on 2 10's daily for about 3 weeks. Granted i knew what the hell i was doing and 2 the enclosure design was CRITICAL on the setup.. They took it fine.. The aluminums are awesome at handling power...
Yes i have people to back that up also.. User error all day.. I may have missed it but that wall you had them in was tuned to?? Space?? Specs on the wall??
Btw did you do that on screwed music??
the box was 4.3 cube w/ port displacement tuned to 32hz
nate2587
nate2587
Lambertville, MI
nate2587
    Jun 24, 2026
    Jun 24, 2026
