Better Amp- Hifonics Goliath or Crossfire 4000D
depends on what ohm you need the power at //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif plus the crossfire is rated at 12 volts. The Goliath from what i hear also breaks easier
What kind of electrical do you have? I would feel better with the Crossfire, if you're going to be running it at lower voltage.
Plus I've heard the Crossfire can run at 1ohm unmodded.
The ohms doesnt matter because I will buy the coils to suit the amp I have
I am planning to run 2 solo x 12" (2500W Each)
I am guessing that the goliath would put out a lot more power?
Which is more stable?
Which draws more current?
Just want a few opinions on which is better
I would go with the crossfire. Run it at 1ohm have a strong electrical and your good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Neither, http://www.conceptconcept.com/proddetail.asp?ID=283&ProductLine=Amplifier
Take a look at that monster, DRAWS UP TO 400A that means that these power ratings:
Peak Power 3900W (
RMS Power 1000W x 1 @ 4 Ohm
RMS Power 2000W x 1 @ 2 Ohm
Mean nothing, if your looking for some serious power and bang for your buck i'd go with the CD-3910 over both the Goliath or the Crossfire. Just make sure you have a strong electrical setup for it, as it draws 350-400 AMPS!
solo18x
solo18x
Miami
puka_bum
