I've never ran more then one 4 channel amp for interiors obviously using the headunits front and rear RCA's.
I have 8 mids and ,4 bullet Tweeter's
Two DS 1200x4
And one DS 800x4
I will not include sub and amp in my concerns with this scenario as I am just gonna she the sub out from the deck.
This is for 2 mid amps and one tweet amp .
Im pretty quick to catch on with explanations as long as it's A-Z steps and not too brief , I think this requires someone too at least lay out my options with the particular amps I'm using . I haven't found one write up or illustration yet to show the best way.
I'm assuming a dsp is needed or line driver but I am unsure of which one would be best I'm only seeing mostly 8 channel out which would mean the ability too run two 4 channel amps, not 3 amps .
Using a Prv dsp was my first idea
More importantly how to run the rcas ? How many are used right off the back of the Radio and if there's a big mess of y adapters in this situation.
If I plug in a set of ,4 channel rcas out the headunit to the dsp input side .. whats done from that point on with the 3 amps and getting rcas ran too then from the dsp.
Two DS 1200x4
And one DS 800x4
