best way to remove tint?
no the best way and its easy on you. peel it off. razor blades and old rags. either goo gone or good vinyl remover(smells like oranges) spray on and scrub off might need razor blade for light stuff.
Rags are the absolute messiest way to remove glue. If you want to make a mess use rags.
The easiest method has not yet been mentioned in this thread.
Heat gun or hair dryer, heat up the window from teh outside, and peel slowly.
When hot, the glue sticks to the tint and not to the window.
I work at a tint shop. F*** ammonia - heat gun is the easiest method.
This would be great if it worked for every window with tint on it. Unfortunately, it doesnt. Some will seperate no matter what you do. I always used a torch, but Ive been doing it for a long time..dont recommend just anyone bust out the torch and get after it. For really stubborn glue, Id use simple pink.
Yes
and if you get glue stuck on the window with defroster lines, a scotchbrite sponge with goo gone with work.
i was told to use scothbrite pads the red ones after i wrestle the film off. would doing the rear window be a 2 person job one with the heat gun and one pulling the film off. i have to have all mine redone. my rear window is 3 pieces, and all of my windows have lil bubbles.
blimblam
blimblam
new orleans
W8 a minute
