best way to join two 4gauge wires
WiNnErPL
nYc
Hey guys it turns out my main 4gauge cable is too short after I needed to cut a piece off. I order about 5 more feet of it now my qustiion is which way is the best to join them? Just twisting the wires is enough?
this is a thought i've had, i've never tried it and don't know how well it'd work but it's worth a try: crimp a ring terminal to both ends of the wire and then use a nut and bolt to attach the 2 rings together, then use heat shrink tubing or something to cover up the connection
if someone could say if this would work or not that'd be great
i would just get another fuse box(like the one next to the battery), that is if u have room for it were the wire is split....nice n semi clean lookin
or you could just add a fuse connection :-/ its the way you connect the same wire to itself where you need the real fuse.
And i dont know of any problems of adding a second fuse farther down the wire either.
I would not wrap the wires together. Go get another fuse block, or a terminal block and do it that way. Do not scrimp, or you might not like the results.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
748
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
653
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
843
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
WiNnErPL
WiNnErPL
nYc
tomd
chillin
    Jun 14, 2024
