cannonwillow
I currently running a monoblock autotek m2500.1D amp rated at 1250 watts rms running at 1 ohm. This is in a 94 ford e150 conversion van with a raised roof and with no middle seats.
I have 2 well sealed boxes behind the rear seat firing upwards. 1 box has a 15 inch mtx thunder 8500 subwoofer with 4 ohm DVC's rated for 600 watts rms. The box has a volume of 2.539 of cubic feet. Recommended by MTX is 2.00 volume for sealed box and a volume of 2.48 for a vented enclosure. The other box has 2 kenwood 12 inch subs in a dual box. The 12 inch subs and box were bought as a unit. Dont have the particlar stats for these 12 inch subs ATM. I think I wil have to pull one of them out of the box to find the subs model number. But they do have 4 ohm SVC's. The boxes are anchored to the floor and each other.
I am running the 2 12's and DVC 15 all in parallel resulting with 1 ohm load on the amp. This should be sending just over 600 watts rms to the 15 inch and just over 300 watts rms to each 12 inch sub. Have 2nd battery under the rear seat ran with 2 gauge wire from front battery. Also using a 2 farad cap and very short lengths of 8 gauge wire for the amps power and ground.
The bass hits hard and sounds good to me but am always looking for improvements. Especially low cost ones.
I can reduce the size of the 15 inch subs box to get it down to 2.00 cubic feet easily. Or I could vent it since it is just slightly larger than the recommended vented enclosure size already. Would it be wrong to mix both vented and sealed boxes. I have a very large amount of open cabin volume in the van. Would I be better off getting another amp so both boxes can be independently adjusted.
thanks in advance for any advice all. My first post here...
