Best subs for this box?
sizzl3r
Sup /enclosure design
My friend is going to be helping me make a box identical to this one:
Ford Ranger Extended Cab 12" Ported Down Fire Grey Subwoofer Sub Enclosure Box | eBay
I don't know too much about airspace, because all of the setups I've had already had boxes/subs, so I never worried about it. I have an MTX 600D (300 rms @ 4ohms, 600 rms @ 2 ohms) that I want to power 2 12'' woofers. What would be some good options that would work with this setup?
I would want them to be either 4ohm svc or 2ohm dvc so I could get most out of this amp.
Price range: Let's try to keep it $200 or below.
Thanks ;D
Don't make a box like that one, that one isn't really that good.
Get a good design from one of the box builders here instead, you'll have much better results
And is it $200 per sub, or $200 for both?
after you build it with 3/4 mdf it will be smaller internally ,also the port is too small .might have enough air space for 2 10's if you follow that box and open the port up a bit.i wouldn't use that design ,talk to some of the builders here you'll get a better box and better output from the box.i would also do subs up and port up if you want loud .look at the american bass xfl subs too.
I guess it's pretty consensual that I shouldn't follow this design. I've never gotten box design help here before, how do I go about doing that?
I'd like to shoot for $200 total.
sizzl3r
sizzl3r
Minnesota
sizzl3r
