Best subs for this box?
  • 4
sizzl3r
Minnesota
Sup /enclosure design
My friend is going to be helping me make a box identical to this one:
Ford Ranger Extended Cab 12" Ported Down Fire Grey Subwoofer Sub Enclosure Box | eBay
I don't know too much about airspace, because all of the setups I've had already had boxes/subs, so I never worried about it. I have an MTX 600D (300 rms @ 4ohms, 600 rms @ 2 ohms) that I want to power 2 12'' woofers. What would be some good options that would work with this setup?
I would want them to be either 4ohm svc or 2ohm dvc so I could get most out of this amp.
Price range: Let's try to keep it $200 or below.
Thanks ;D
Don't make a box like that one, that one isn't really that good.
Get a good design from one of the box builders here instead, you'll have much better results
And is it $200 per sub, or $200 for both?
after you build it with 3/4 mdf it will be smaller internally ,also the port is too small .might have enough air space for 2 10's if you follow that box and open the port up a bit.i wouldn't use that design ,talk to some of the builders here you'll get a better box and better output from the box.i would also do subs up and port up if you want loud .look at the american bass xfl subs too.
I guess it's pretty consensual that I shouldn't follow this design. I've never gotten box design help here before, how do I go about doing that?
I'd like to shoot for $200 total.
Will do. Should have it figured out by next week
24
4K
Was thinking missionary, can really take a pounding that way
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
293
sizzl3r
sizzl3r
Minnesota
sizzl3r
    May 12, 2024
Brendon Jenness
    May 11, 2024
