best subs for the $$
MATT2007
Ok I am looking at getting 2 10s that will handle between 400-550 Rms I looked in to 2 alpine type Rs but I heard from some people that there are better deals out there I don’t want to spend over $350 on the 2 of them they will be going in to a sealed box Right now I have 2 12 in dubs with a 1000 watt profile Baja amp I would like to keep the amp because I really like it any help would be great
First, the Profile amp isn't going to put out that amount of power. I'm guessing you have the HA1000, which is rated for 160W x 2 @ 4, 240W x 2 @ 2, and 480W x 1 @ 4. Your best bet would be to get a new amplifier that is more suitable for the subs you currently have than to get 2 subs that are rated for something that this amp can't even put out, so you'd be very disappointed, and either clip the signal to get 'more' output or have to buy a new amp anyway. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I will be using DVC subs so I can bridge the amp my subs handal 400 RMs and my amp puts out 480 Rms
Exactly, your amp puts out 480WRMS, your 2 subs handle 400WRMS EACH, so 2 x 400WRMS = 800WRMS. Or we can put it this way, 480WRMS/2 = 240WRMS that each sub is seeing.
Get one DD 512 in a ported box....It will play louder and hit lower than the 2 subs you have ...and will run within your price range....
Good choice, I just looked this up 'cause I thought it was a typo. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif I didn't know they made a 500 series. I might have to get some.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-414
You will be very pleased with the SQ, SPL, and overall sound these ****s produce.
Not going to work for his application, he needs either 2 200WRMS woofers, or a single 400WRMS woofer.
2 of these = $300 even
Good choice, if he goes with a single woofer setup.
ok I have both of my subs wired at 8 ohms then hooked to a bridged 2 channel amp which puts out 480 watts X 1 at 4 ohms so how am I not geting 480 rms to each sub
MATT2007
MATT2007
Maquoketa IA
shortyg83
