Best sub setup 2018 f150 super crew
You would need to double cone area or power to experience any worthwhile gains in general. That being said 2 8s is 90% of the cone area of a single 12 so you'd need 4 8s for noticeable gains.
What kind of enclosure is the Q12 in and how is it oriented in the vehicle?
I will have to double check dimensions. I think it is around 14x14x16 with an octoport facing up behind the passenger seat, where the small portion of the back seat folds up.
I’m not real sure I can even fit quality 8s in a box like this back there.
On on a side note, I really don’t have money to spend on the upgrade, however, I have the current q enclosure and an old school cerwin Vega Stroker 15 in a ported box to sell. Not sure how much I can get out of everything
Check those dimensions, it sounds like that Q is in a seriously undersized enclosure. Putting it in a properly sized enclosure will make a big difference.
If I am doing the math correctly, this equals 4.125 cubic feet.
I think FI recommended 2.5 cubic feet.
You need to subtract the thickness of the walls,  sub displacement, port displacement and bracing displacement. Its probably around 2.2-2.5cf.
So,  are you saying I could do noticeably better with a better amp than the JBL BP1200.1?
What version Q do you have? Is it a neo or ferrite motor?
Either way, you are underpowering that sub due to impedance rise.
Upgrading the amp would be a good idea but you will also need to upgrade your electrical system so it can sustain the current draw of a more powerful amp.
Which amp?
my FI Q is old. See the pics. Not neo.
They have a 50 amp glass in line fuse by the battery that keeps popping with the volume up and the headlights dim as well.
I know I need to upgrade the big three
Which amp?
Thats an older style Q, I'm pretty its still a 1krms sub. Upgrading to a 2-2.5k amp would be a good idea. A 50a fuse it too small for that JBL amp, bump it up to a 100a fuse. What size wiring do you have?
jeeper2269
jeeper2269
Somewhere, OR
THATpurpleKUSH
