Best sub and amp + enclosure for under $200
Broese
LA
I would be putting it in my 96 Pontiac Bonneville. It's got a fairly large trunk (18 cubic feet) and I dont want the sub to take up the whole trunk. I don't need it to be crazy loud or anything. I just want the lows of my music to sound good too. I usually listen to mostly rock with some hip hop and other varieties and a medium volume. I could build the enclosure myself if necessary. Any help and recommendations would be greatly appreciated.
I'd worry about the amplifier being of low quality with this budget. A more realisitc budget would be around $300. I'd split the money this way:
Subwoofer+pre-fab sealed box = $150
Amp = $150
For subwoofer, I'd pick something a 12 with reasonable qtc in a typical sealed box (1 to 1.5 cu ft). At $100, I'd look at RE Audio SRX12, either 2ohm or 4ohm DVC depending on the amplifier configuration. These are good value if you buy it for just $100-120 online. Sonicelectronix had them on sale for just $70. It's well suited for a 1-1.2cu ft sealed box. (~0.7 qtc in 1.2cu ft) Very good throw (18 mm or so). I had one for a year, and it was a good subwoofer. Very music and surprisingly good impact for a sub powered with a 250watt amplifier. If you can afford it, an Infinity Kappa 120.9w would be nice for a small sealed box as well (it usually costs around $140). This enclosure could work well:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-644
What if I got RE Audio SRX12D4 for $70 and Sony XM-1S for $80 then an enclosure?
Give it 1-1.3cu ft sealed box stuffed with polyfill. I have seen a test of a Sony XM 4-channel amplifier with test results looking decent, but snr was in the 70s. But then gain, this spec probably matters less for subwoofer.
what I f I used the same amp and setup for the Infinity kappa?
$85 shipped, does a true 1k
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
https://audiolegion.com/collections/monoblock-amplifiers/products/al1200-1d-1200-1d-monoblock-car-amplifier
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
https://www.ctsounds.com/collections/ct-series-amplifiers There was a Sale recently.. May want to wait for a Thanksgiving Sale or Halloween Sale...
Broese
Broese
LA
04murdalanche
    May 16, 2024
    May 12, 2024
