Best SQ Setup???
Big vote here for a Mag V4, or two.
Absolutely transparent with little to no tuning. Up front bass is easy with the mag V4. Little low on the output, but I think much of this is mental since how transparent it is.
I still need to try many other subs but for SQ I love the mag.
yeah, if going to SQ i would spend a lot of that on deadener. I would rather have solid doors and mediocre speakers and amp over good speakers in a non deadened door. SQ starts with the front and works its way back.
if you are willing to start out front, if you do some reading, you will find pretty darn fair prices on a DIY front stage. mach5 6.5s and seas tweets active should not break the bank and will sound great with deadened doors.
Read more than this one thread before you spend your money!
you might even want to head over to diymobileaudio to read some things... its more of a SQ environment. check classifieds for your purchases.
order of purchases for sq
high end source with nice processing integrated or external processors.
quality speakers that work well with each other. (can be 2 way or 3 way. I suggest active
deadener and quality cables
quality subwoofer. look for subs that blend well, and are very transparent.
amps are amps. however they are much more if u need their crossovers and if your going all out look for amps with very low thd, high signal to noise ratio and good channel seperation. also class a/b's generally sound better but draw more current
However the truely overrated part of any sq system is the attention to detail and amount of time you put into your install tweaking and eq'ing and tuning your setup
Idmax is one of the best sounding subs ive heard. Mine blends seamlessly with my front stage and can get loud when i want it to.
i cant wait to go IB with mine. hopefully in a few weeks i will //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
do what this guy said. especially going over to diymobileaudio if you really plan to go to the darkside of sq. sq is what they are all about over there and much is too be learned.
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I will look into the big 3 being done here pretty soon. As I said previously you guys are awsome, so thank you for everything. My alpine's came...
10
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
348
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
492
S10DRVR
S10DRVR
Hawaii
Brian_smith06
    May 23, 2024
    May 22, 2024
