Supergumby5000
Project: F350 begins...
Well, my hercules finally came in today from warranty. fookers didnt send me back my end caps or boost knobs tho, they will be gettin a call in a minute.
Anyways, how do you all ground your high wattage amps? I want to make sure nothing happens to the amp this time around. Before, i had a hole drilled through the chassis underneath my rear seat, and just sanded and bolted it down. that ground works fine right now for the two amps i have hooked up atm (4ch alpine and a 300rms kenwood). Will i be okay grounding here or should i look elsewhere? Is bolting a good alternative or is there better bolts than others? welding lol?
