best spl 12
With that power, the Type R's would be very hard to beat. I've tested them against some other "good spl subs" and the Alpines kept up or beat them in every case. I wouldn't have believed it till I tried it myself...you will need to tune a lot higher than 32hz for spl though.
It depends on what sub man I would get the AQ subs and the orion AMP... Orion 2500d are pretty nice and look smooth. The type R's wont sound good at all tuned anything past 34hz. If you got the AQ's (hdc3's) and tune them to 40hz in about 4.5 CF of of that Orion you could put up some decent numbers 1000 watts IS NOT to little power, you just have to build the enclosure accordingly. The AQ's will handle way more power, you could put an Orion 2500 to each of them later on if you wanted.
thanks most help so far
Type r's won't sound good at all tuned past 34hz? They aren't an sq sub, but they won't sound bad. Don't listen to that guy up there.
The DD tank has the extreme cab 20hz avg record….160+ for a minute yes….I have
86
9K
They're rated for 250wrms, so you were overpowering them, especially the poor 10s. XBL subs sound really clean at their limits due to the flat BL...
10
325
481
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
473
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
582
kgrind50
kgrind50
burlington, new jersey
mazdakid
    Jun 1, 2024
    May 31, 2024
