"Crimps Uninsulated terminals AWG 22-16, 14-12, 10-8
Interchangeable dies
Crimping pressure adjustment wheel
Ratcheting action for perfect crimps
Crimp release for operator safety
Elastomeric resin, double molded non slip handle for comfort."
http://images.google.com/imgres?imgurl=http://www.mbelectronics.com/images%255Citems%255C902-154.jpg&imgrefurl=http://www.mbelectronics.com/view.aspx%3Fid%3D91&h=503&w=306&sz=62&hl=en&start=16&um=1&usg=__W2dNsucmhUZAvV9hx5bVMEluWQI=&tbnid=mItj6Kandzkr_M:&tbnh=130&tbnw=79&prev=/images%3Fq%3Dwire%2Bcrimpers%26um%3D1%26hl%3Den%26sa%3DN
we use crimpers similar to these in the navy, and they are super bad ***. they have interchangeable die on them that you can buy different ones for different purposes.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and something like this for stripping the wire would be sweet;
"An adjustable wire length guide helps you make uniform strips, and a built-in wire cutter and crimper helps you complete your wiring job.
* Spring-loaded design
* Strips wires ranging from 24 to 10 gauge
* built-in wire cutter and crimper "
http://www.dxengineering.com/Parts.asp?ID=2444&PLID=200&SecID=105&DeptID=30&PartNo=DXE%2D11055
