okay i read the big 3 sticky now i need help
tuff57
where do i get all the stuff:confused:
im guna have 3 amps in my car eventually and i wanna convert all the battery cable and such over to 0 gauge do i need different terminals for 3 amps?
itll be 1 4 channel 1 2 channel and one mono
i'm eventually going to get a h.o alt but for now where do i get all the stuff to do the big 3 its probably been asked a hundred times but some answers would help
thanks!
joe
I just made an order off knu last night. I've looked at other stores for car wire, and knu has the best for the lowest. Before you order, make 100% sure you know what lengths you need, and add a couple feet. Also, make sure you leave room for a possible battery in back, depending on your amp setup and current draw.
I took spare speaker wire and did a mock "big 3". I made sure to figure in the size of the 1/0 and its flexibility. Then I just measured the speaker wire I used, and tacked on 6 inches per run of wire, for stripping/just in case.
Do exactly as he did. You can use any type of string, rope or wire. Just do a mock up run and measure the lengths you came up with and add 4-6in to each length.
tuff57
tuff57
long island, ny
QtrHorse
