Best really cheap 10" subs??
Too bad hifonics doesnt make those hfi's in a ten inch version. Those are shaping up to be some of the best bang for the buck subs ever. I hope you find what you are looking for. Ive been throwing around a similiar setup myself.
think it will get pretty loud? I was figuring on about .7 net for each sub....Hifonics eh? I saw them on Ebay.... What about the MA stuff.. I Have the HK802sx amp, it would be cool to run the same brand subs, are they any good?? This setup should slaughter a single 15 ported right? I would think so but I don't know anything about multiple setups...
Slaughter? Most definently.
You should run them in a bandpass. Really draw out the bass from them.
Im running 4 hfi 12's, in a 4th order. And it kills.
Sweet, that's what I'll do then, but I can't do ported, WAY too big a box, if I leave em sealed at .7 net each, I end up with a mIni wall at the back of the cab about 7" deep and only 25" tall, plenty of room in the rear for the dogs and storage...
OK I think I'm down to these cheapos, but with 8 of them, I am sure it will hit pretty good! 250 watts RMS each, equals 2000 watts for the set of 8, I think with this much cone area it should do quite well, even sealed. I will be running each sub in .7 CF and I will likely try more power, they say 500 each peak so maybe like 300ish. As long as they out do my single 6th order AQ 15 I will be happy, I am not going to a comp or anything. I just need more space and this will do it. I know they won't get as low most likely but I mostly listen to rock anyway with the occasional rap. What do you guys think it will do?
Fuknmovin
Fuknmovin
Palm Desert, CA
SicAudio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
