Best really cheap 10" subs??
Too bad hifonics doesnt make those hfi's in a ten inch version. Those are shaping up to be some of the best bang for the buck subs ever. I hope you find what you are looking for. Ive been throwing around a similiar setup myself.
think it will get pretty loud? I was figuring on about .7 net for each sub....Hifonics eh? I saw them on Ebay.... What about the MA stuff.. I Have the HK802sx amp, it would be cool to run the same brand subs, are they any good?? This setup should slaughter a single 15 ported right? I would think so but I don't know anything about multiple setups...
Slaughter? Most definently.
You should run them in a bandpass. Really draw out the bass from them.
Im running 4 hfi 12's, in a 4th order. And it kills.
Sweet, that's what I'll do then, but I can't do ported, WAY too big a box, if I leave em sealed at .7 net each, I end up with a mIni wall at the back of the cab about 7" deep and only 25" tall, plenty of room in the rear for the dogs and storage...
OK I think I'm down to these cheapos, but with 8 of them, I am sure it will hit pretty good! 250 watts RMS each, equals 2000 watts for the set of 8, I think with this much cone area it should do quite well, even sealed. I will be running each sub in .7 CF and I will likely try more power, they say 500 each peak so maybe like 300ish. As long as they out do my single 6th order AQ 15 I will be happy, I am not going to a comp or anything. I just need more space and this will do it. I know they won't get as low most likely but I mostly listen to rock anyway with the occasional rap. What do you guys think it will do?
Fuknmovin
Fuknmovin
Palm Desert, CA
SicAudio
