best overall amp electrical wise
of those i would guess the fosgate followed by the vfl. the other two, i've heard are current hogs, but any amp that large is going to need significant electrical support.
what does your charging system consist of?
MA amp should be avoided. The ONLY reason people use them is they do a ton of power at 18-20V in and count as "50W" amps in some orgs.
Can vouch that the RF amps are reliable. Really the way to get really efficient is to buy an amp that does say 8KW at 1 ohm and run it at 2 ohm. Most of these big boys are not terribly efficient when you drop them down to super low impecence.
i kinda figured the ma was bad n the rockford was my first choice but wanted to see if anyone had experience with cadence or the soundstream before i spend my money
i know the memphis 4k isnt efficient by any means, but i've got a 34 series optima yellow top up front, with 3 134ah c&d batteries (100 lb monsters) in the back, double 1/0 big 3, triple 1/0 connecting front to rear, and at 1.2 ohms nominal i still get voltage drops if i'm pushing it.
get batts, son.
keefy248
BID BIG
keefy248
DETROIT,MI
hispls
michigan born
    May 14, 2026
michigan born
    May 14, 2026
