Best Ohm load?
Firstly, ohms are inaudible. They will not make a system any louder or sound any better. Your Legacy amplifier is likely only capable of a 4 ohm load. You will need to bridge your amplifier to 2 channels and then run it to the woofers at 4 ohms stereo.
If you look at your amplifier or in its owner manual, it should explain the correct way to bridge your amp- thus allowing higher power output at 2 channels.
4 ohm subs are your best bet with a 4 channel amp such as the one you have.
take it easy,
-zane
The amp also says that it's capable of a stable 2ohm load. But safety wise, do you think 4ohms would be best?
Volfenhag21
Volfenhag21
Michigan
ThxOne
    May 13, 2026
