best glue?
Nope, Titebond II all the way, the gorilla glue expands too much for me
hm... did it hold good though?? (the GG)
The expansion could come it handy for minor imperfect{SP} cuts... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I held fine, but it was a small, low powered box for a single 10" so most anything probably would have worked, and the silicone bead on the inner seams after assembly is best for airleaks from imperfections.
Tightbond and Elmers form a chemical bond with the wood creating a joint that is stronger than the wood itself, I am unsure if Gorilla Glue does this.
.... now i am worried.... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i might drive back to home depot and switch it out...
Only downfalls I've found to using liquid nails over silicone is it stinks a little bit more, and can make a huge mess. Good luck getting that shit off clothes, skin, anything. Other than that I don't see how it "sucks ballz".
I always use titebond.
I did a wall last year and used LN and screws to attach 2x4's on the outside for bracing. Used a ton of that shit. 4 weeks later when I took it apart the 2x4's fell off when I removed the screws //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Gorilla Glue also sucks. I've broken apart 3 enclosures I built using that stuff and all broke at the glue joint without delaminating the MDF.
TBII or Elmer's Pro is all I use now //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Titebond II
No need for titebond III, since you don't need it to be waterproof. Gorilla glue is a pain in the *** for boxes, and liquid nails sucks my nuts off.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
Actually now that you mention it, I know what you're saying. Vibration can cause dried up liquid nails to just crack. I learned that on a non-car audio related project.
As a sealant it shouldn't be too much of a problem but I'd never use it to hold a box together. I still prefer clear silicone though.
As said before, titebond = chemical bond, the gorilla glue does not form one, just a physical bond.
lol expands? it freakin swells LOL I tried fixxing a wood clock that fell off a wall with it and it left a gap so wide i hade to use wood filler on it then use a wood stain marker to cover that. Stuff is strong though
I used liquid nails silicon and fiberglass to hold my built to box together (back of my box is the cab) and it is over 4 years old. no leaks or cracks
As long as it's made well, I wouldnt see why it would have any leaks etc. in it...
Very good enclosures can be made with just about any of the mentioned ways, its just alot better of a bond with wood glue, screws, and clamps for added pressure on the joints as they cure..
Titebond II
nG
x2 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Only difference in I, II, and III is level of waterproof...ness?
And just for the record, I use titebond III. Glue only joints FTW //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
my latest build is glue only other than to hold the inside sections of the ports in. using tightbond II
302yota
302yota
rockingham, NC
audiolife
