Best Components?
Is it better to mix and match tweeter, x-overs, and a midrange from different companies or is that overkill? If not, where is a good place to find those items?
if you're going to do a full component set (including the crossover), it's best to stick with a single company (this is referred to as a "passive" setup). if you're going to go with an "active" setup, you can mix and match drivers. an active setup would be without a crossover. you would use external processing to set the crossover points in a setup like this.
for raw drivers for an active setup, you can check out the following sites:
http://www.partsexpress.com
http://www.madisound.com
I like the sound of the Focal tweets, I do not like how the driver handled the bass, especially for that price range but i guess that could all be taken care of with proper tuning
I'm not a fan of focal tweeters. But i think the rsd's can be beat for 400 dollars. Just nothing is coming to mind at the moment because i am so wowed by them lol. I'll sit around and think for you, and go listen to my rsd's
my apologies, i read this^^ and didnt realize it was from skydeaner instead of 03 acura tl. my bad.
So is there a better choice than the Focals (the 165V2 polyglass or base poly kevlar) in that price range or less? If not i might have to pick up a set.
yes i did a review on them. they are very nice speakers, they sound amazing especially for the price. i'm not the first one on here to recommend them though. i bought them cause others on here had been suggesting them. have you heard them properly installed and properly powered?
03 Acura TL
03 Acura TL
Oregon
desertheat
michigan born
    May 14, 2026
michigan born
    May 14, 2026
