Best Blow Through Sub box
I'd look at running the subs @ 2 ohm. It will be more efficient and easier on an amp. You could look into a 2 ohm stable amp like Alpine or Kicker. You can purchase a 1 ohm stable amp that would give you the power you're wanting @ 2 ohm but you'll end up paying more for the power. What kind of vehicle is this going into? What are your max dimensions and what are your overall output goals? Depending on what you're looking to achieve and the room you have, you could run the subs in a 4th order or 6th order install.
im looking to do either a blowthrew or 4th order in my 98 civic with 2 sa-12 d4's running an old ppi power class 21400.2 i can give the demintions if youll help or know anyone who has done this before
malandrin4o8
malandrin4o8
San Jose, Ca
dmuney
