OP
Vinson Clark
- Thread Starter
- #31
So should I get a SA 12 D4 or D2 and run at 1 ohm? I'm getting confused now I just want a nice single 12 in my truck that's hits hard I'm not trying to make things complicated that's for sure ESP since this will be my first system.theres no reason to buy the cab 1600 if you only plan on running at 2 ohms. You can get some other amp that does power at 2 ohms instead. After box rise you'll barely see 300 real world watts going to your sub. at 2 ohms. There's a reason why We recommend running a lot more power than needed. The actual amount of power you see wont even be anywhere close to what the sticker says. Its basic physics, unavoidable for any amp. For the CAB, if you wire to 1 ohm, you'll have 2 to 3x the box rise which means you'll see power between 2 and 4 ohms which is about 750 watts once things are done. The reason you want more power is because you are using a pre-fab not optimal box as well which will limit how much output you'll get.
Why am i running 30k power to my 4 subs that are only 4k rms and never even got close to heating up the sub? Its because the signal is clean, amp is efficient. A lot more cases of blown subs and amps happen from newbs not being happy with the output they get and they start to crank things up when the amp cant provide anywhere close to enough power.
