Best 10" sub
Benkeico
(4) 10 inch subs. Best Sq for the $$$, Lets say we have 100 each, or if we can do it for less great, if not thats cool too.
I want to do 4 10inch sub instals. Fiberglass. In a Bronco 2 i really want sq, but with a little power... Mabey try 2 10's and 2 15's but hehe, i dont think so...
Links are great, but i am more then greatfull for just names and ect.
Thanks alot Guys.
Ps I was looking at infinitys 1030's the 10s but i was told they blow easy?
Editied, cause im bad.
resonant engineering
adire audio
digital designs
incriminator audio
infinity
cerwin vega?
sigh - there are a few more but i cannot remember them, its eairly.
i have 800watts running to a single resonant engineering SE 10" and its nice and loud.. and sounds good (even though i got some small holes in my enclosure that im too lazy to fix)
if your looking at ~100 watts and 10" speakers with real good sound quality, why not go with 4~6 8" adire audio drivers?
these 8" subs from adire are supposed to sound amazing at 100w and have incredible sound quality. thats what i would do if i were you.
maybe 4 8" adire subs with 1 12" adire in the center. that would look sweet. (and loud)
ported?
if you want SQ i would be seriously looking at the 8" adire audio subs- $89 a piece i believe (not sure) and i would guess ~.2 cubic feet per sub sealed. much smaller than a 10 would require.
supposedly amazing.
Never mind, But yeah so the 8's look good.. i havent used Audio Adrie, but i will trust you guys... What amp should i use with thoes, cause like, uhhh,,, its like 300 rms, 600 peak. So i would need need to put a 1200 amp Rms at 4 ohms?
Or would that be 2 600rms 4ohm, or something like, so two amps of 600rms?
Or hell what amp should i use, and how should i wire it?
The infinitys wont blow easily, you can get some kappas or perfects off ebay for cheap. Infinity does a test where they run the subs at full power for 24 hours (high end subs). The perfects sound great and hit beautiful. Infinitys use 1.0 per sub, and are very efficient with amplifier power.
Benkeico
Benkeico
Napa Valley, Bay area
Depression
