yea and i know it sucks balls on lowsi am running 2 12's l7's in a 5.2 net box with one 6" aero tuned to 34hz on 1500rms
idk i havent heard ur setup. just the diff in mine. ur ports would be much much longer if u used two instead of one. go get metered and ill tell u if ur box is doin the numbers it should. i just know mine blew on any thing under 38hz but the slot peaked at 37 and was much louder to the ear.well mobeious designed the box so if it needed more port area wouldnt he of put another aero in it or wat
and if i want to i can always go and add another port in it if i really need it
and i will loose .16cuft of airspace and will i gain anything with another 6" aero how much louder would it be or would i not notice it
extended cab i assume? i saw a guy yest. do a 145 at the headrest with 4 8's and 1200 watts. i saw a guy do a 145 with 1500 watts and 1 15. so idk man get it done at the headrest and tell us.yea i couldnt of really went with 2 6" aeros since the aeros would of been around 23.5 long and the box is only 26.5 long inside so only would of gave around 3 inches between the box and the port doubt that would work that good
the box dimensions are 32 tall 28 deep and 13.5 wide thats external and the subs are facing the roof and port is firing back
so one 6 inch aero would of been the only possible way i think
so being around 5.2net tuned at 33-34hz on 1500rms in a f150 truck wat should i be doing on the TL
